Stack “Backgrounds” upgrade
Hi Guys
…a new stack, Backgrounds
This stack makes dynamic hero areas using cutting edge browser visual effects!
Multi-layered background with CSS Blending Effects; You can add both images and gradient by changing the blending mode.
stack_backgrounds_top
Flexible column with custom width & alignment with breakpoints.
stack_backgrounds
50+ Models ready to use
stack_backgrounds_samples_1
stack_backgrounds_samples_2
5 projects for RW frameworks
stack_backgrounds_frameworks
demos frameworks
thanks to everyone!
New UPG 1.0.1 Available:
  • Fixed column alignment issue
  • New examples using the blur backdrop-filter combined with the gradient, 6 templates (pages 17 & 18)
  • Demo project updated
backgrounds_multithemes_6_new_demos
Is there somewhere to get this update as it does not show up in the Stacks updater?
Also I’m wondering if this release fixes the rounded corners on a slice as I have not been able to get that to work for me at all, even though I can see it working in some of the samples it does not work in my project?
Normally we send an email to all customers, drop me a message with your email. You can also download the update with your purchase link.
I’m not sure to understand the problem, in any case you can customize the rounded corners.
You can also change the radius in small devices with breakpoints.
Screenshot 2
BTW: with the Backdrop Blur Filter activated the Rounded Corners option is not available
New UPG 1.0.2 Available:
  • Solved issue in Scroll button
  • Extended range for Scroll button speed
  • Extended Range for background Opacity
  • Demo project updated 4 templates (pages 19 & 20)
backgrounds_UPG
New UPG 1.0.3 Available:
  • Solved issue in Scroll button (CSS)
  • Demo project updated 2 templates (page21) with animated GIF
bg
New UPG 1.0.4 Available:
  • Extended range for Layer 1 opacity
  • New option to sticky the slice content at the top of the stack
  • Updated HypePro® Animation Core
  • Demo project updated 3 templates (page22) with animated GIF with cool effects!
backgrounds_upg
If you like this stack, please consider to leave a Like or even a short review over at the RW Community page
New UPG 1.0.5 Available:
  • Updated Animation Core to latest version of HypePro®
  • Updated Blending JS library
  • Solved issue in scrol button
  • Solved issue if used with CordialPro Theme
  • New samples in Demo Project
Samples
New UPG 1.0.6 Available:
  • Solved issue in linear gradient color 1
  • Optimized User Interface in “Edit mode”
  • Optimized CSS code
  • Increased loading speed in “Preview mode” & “Edit mode”
backgroundsUPG
New UPG 1.07 Available:
  • Updated animaiton core.
  • Solved issue if used with HypeTitles Stack.
  • Improved performances using CSS blending
bg
Here a coupon for all RW4All guys, 20%off backgroundsrw4all
Thanks!
