I’m happy to present the first MultiThemes stack. As many know MultiThemes develops themes but my great passion for HypePro has allowed me to create new content for RW like Lux and Hype Themes.
This is the same animation of HYPE theme but available in a stack ( with some minor differences)
The HypePro based Stacks is the next generation of packages with original contents for RapidWeaver. All animations are designed exclusively for Stacks. This stack allows you to set 16 animations. take a look.
I must thank to some great guys like my friend @willwood, also Tommy/DeFliGra and @Marten for the help. this is a great community! A great thanks also to Jonathan Deutsch and the hype community, I have many friends!
Here a coupon for all RW4All guys, over 20%off (for a limited time) hypetitlesrw4all
thanks!
@Marten thanks, I worked a lot for this project but the major merit is HyperPro and I’m working on new stuff also. Now I’m focused on this stack, ( my first stack) and the improvements.
Thanks @wolf.ademeit
yes the UI in edit mode is useful, I had fun doing it and I tried to be minimal (in order to save memory In edit mode) I made it responsive but I would like to improve it on small monitors.
This looks amazing. Pretty fun dragging around the sliders on the demo pages. Surprising how fast and responsive these animations are. I didn’t even know some of that stuff was possible in a web browser!
@Multithemes
For the use of custom fonts, it would be useful to be able to set the font thickness. Otherwise you always load the normal version.
In any case, a stack that succeeded very well …
@isaiah thanks!
The slider is the most appreciate part of the Stack! I had a lot of fun to do that :)
Thank to your “Preview” option Stacks allows me to add further tools also in preview. The Grid and the sliders helps you a lot to build the title correctly.
%%[[if preview]]%%
something special
%%[[endif]]%%
not sure to understand, in all pages you can find 16 links but this is a demo toolbar for preview only and you can test all styles without refreshing the page.
@MrTim maybe it’s my fault! I didn’t specify the difference between custom examples (from 1 to 25) in the demo site and the 16 templates of the stack. Sorry :)
Fixed issue of the Stack panel in edit mode in Stacks4beta.
Now you can load a background image and also enrich the layout with a dots grid in 10 styles (example).
I improved the preview option with a small toolbar to run all animations without refresh the preview! this is unusual in RW but possible through HypePro!
I’m making a priority list and I thank everyone for your valuable advice. I will also examine the compatibility with other stacks or themes that manage external fonts or libraries. I remain focused on the proper functioning of the animations because it is the core of the stack and must work well!
thank you all
@Multithemes Please advise if I am a numbskull but there does not appear to be any difference between the original stack and the latest version in terms of being able to use a warehoused image for a background ??!
