New UPG 1.1.3 Available:
- New option: Outline for titles with customizable thickness.
- New examples in demo project, 2 templates
New UPG 1.1.4 Available:
thanks again to everyone!
New UPG 1.1.5 Available:
If you like HypeTitles, please consider to leave a Like or even a short review over at the RW Community page
thanks !
New UPG 1.1.6 Available:
thanks!
New UPG 1.1.7 Available:
This is a technical update on performance, the code has been optimized and the stack is faster and more fluid even in “edit mode”
thanks!
New UPG 1.1.8 Available:
Here a coupon 20%Off for all RW4All guys: hypetitlesrw4all
New UPG 1.1.9 Available:
Hi,@Multithemes,
I have your Hype Titles stack which I have used for one project, a couple of years ago. Now, I am ready to explore it a bit more.
Do you have a recent demo project (preferably in ‘Source’ framework) that includes all new features and styles of the latest version of your stack?
Hi Rom, in the DMG file of HypeTitles you can find some Frameworks projects. Foundation, Platform, Source and Ulkit.
BTW: the framework must be installed to open the project properly.
Hi, @Multithemes,
I do have a project file, but it is quite old (I bought your stack soon after you’ve released the initial version). Since then, there were several updates to the stack and some added features. I thought you might have a newer version of the project file, as well…
By the way, do you have any documentation/workflow tutorial for Hype Titles?
All stacks updates delivers new demos in the attached project. I send updates via email. In PM I will send you the update.
BTW: you can also use the original link of your purchase to download the update.
To explore options you can use an existing demo, this is the fastest way.
OK, this is all good if someone updates stacks by going to your website and downloading a new installer package. But I am using internal update system of RW, so all I get is the new version of the stack, without any peripheral files. And how am I supposed to find the original download link from a couple of years ago? I do not get email notifications about updates from you.
BTW, the download link that you’ve provided in Private Message points to the Hype Theme instead of the Hype Titles stack.
I’ve sent an email with all links
Thank you, @Multithemes. Now I got all I needed. 👍
perfect 👍
