New stack “SOLID” with HypePro under the hood.
This is a fairly special stack and I hope you like the concept. 5 Templates with Custom options for images and text.
Demo online
CSS 3D Transforms in RapidWeaver
All animations are designed exclusively for Stacks. take a look.
Some examples (demo project availabe with the stack)
Demo projects for all Frameworks: Foundation, Foundry, UIkit, Platform and Source.
thanks!
New UPG 1.0.1 Available:
- Added new LINK option with STATIC or HOVER states!
Now you can animate the solid also with your mouse (by adding a link).
The new option is based on Hype Animation and the link is handled via Hype.
Note: The option “open in new window” is avaialble in the stack ( hype code overrides RW)
- Erased old LINK option (sorry for the inconvenience)
- Fixed issue in Animation n1 ( horizontal )
here 3 examples, LINK+hover & LINK (static) & No LINK
New UPG 1.0.2 Available:
- Fixed issue in animation n3 ( the slider in preview mode)
- Fixed issue in text colour (on second surface)
- Fixed issue in Text alignment
New UPG 1.0.3 Available:
- New (cool) option to add a Border to solid with custom style, thickness and colour.
- Improved responsive behavior in horizontal and vertical templates (n1&2).
- Fixed issue CSS filters (blur)
10 examples with the new frame
With the border style in dotted or dashed you can create interesting effects,
New UPG 1.0.5 Available:
thanks again to everyone!
@Multithemes I assume the update is version 1.09 as stated on the stack in RW
Thank you for the update and effort.
yes, 1.0.9 is also available via the stack update. Sometimes I also add some new demos into the project.
thanks !
New UPG 1.1.1 Available:
- Optimized User Interface in “Edit mode”
- Optimized CSS code
- Increased loading speed in “Preview mode” & “Edit mode”
- Updated Demo Project with new demos
Here a Solid coupon for all RW4All guys, 20%off
stacksolid6435353
thanks!
