Stacks 5.3.2
I see there is a new update for Stacks: v.5.3.2. but no mention on Yourhead website. Anyone know if this has fixed reported crashes with macOS26?. Anyone tried it?
This was posted yesterday.
https://yourhead.com/appcast/RW6/Stacks5/release_notes_5.3.2_6389/
Many thanks! Was this on Discord? The release history under info on the website is unsecure and out of date.
Yes it was…
Josh did post in here as well under Mac OS Tahoe and CLASSIC - #42 by StacksWeaver
I tried V5.3.2 on Tahoe and it works well. Thanks @isaiah. I only experienced a couple of crashes when I tried to transfer a large number of pages from one project to another or upgraded a RW8 project to RW9.
Question: @Jannis Apple have just released 26.0.1. Will V5.3.2 still work on this new release and not experience any of the previous crashes?
I guess yes.
I’m on 26.0.1 and RW8.9.3 + Stacks 5.3.2 are running just fine.
@wolf Good to know. Thanks.
I’m using Stacks 5.3.0. I’ve had no update notice! Is this a known problem? Has the update process changed and I’ve not been keeping up?
Could it be that you are not using a beta version of Stacks and therefor are not getting update notices for the new beta? I’m not sure if Isaiah has released 5.3.2 officially to the public (via auto-updated) so far. That would explain that you get no update notice if you should be using the ‘normal’/official version. Just download the current beta of v5.3.2 directly and you’re good to go…
Cant recall too clearly - before my morning coffee :sweat_smile: I definitely got an update notification from somewhere however, and pretty sure it was a simple ‘click to install’. Then went to see whether it was addressing Tahoe issues but couldn’t find anything. I do have the beta of Stacks Pro installed which maybe gets the updates?
But 5.3.1 is out of beta?
I’m at 5.3.0!
No idea if 5.3.1 is ‘out of beta’… Just download the official version of 5.3.2 and you’re good to go: Downloading Stacks
I was using Stacks 5.3.0 and the first thing that happened when I opened RW was the update notice to Stacks 5.3.2.
This :point_up:
Nah, not running a beta version. But will just manually upgrade to the new version.
