Stacks 6 Beta 76 is out, and it’s a big one
Isaiah just shipped dev-beta 76, and he’s calling it the biggest UI update to Stacks in a long time. It’s also the furthest Stacks has moved from the old plugin days. To get it, turn on dev betas in Settings and check for updates.
Download Stacks 6 Beta 76
Here are the highlights:
  • One source list. Pages, Partials, Layouts and Images now share a single left sidebar. Part of the reason was Liquid Glass issues, but mostly it makes the workflow simpler.
  • Optional integrated Library. A new setting moves the Stack and Theme Library into the left sidebar too. If you’re on a smaller screen, try this first. You get a good chunk of space back.
  • New Settings window. It’s fully native SwiftUI with Liquid Glass. Clean and modern.
  • Rebuilt info sidebar. The right sidebar was rewritten as dynamic, programmatic UI that adjusts its spacing for your OS version, so it fits both the tighter pre-Glass look and the roomier Liquid Glass one. This is a huge change and Isaiah expects to keep refining it, so tell him if any part of it feels clunky.
  • Experimental high-density mode. Drag the info sidebar to its narrowest width and the horizontal margins shrink to the bare minimum. Widen it and it snaps back to normal. MacBook Air folks, please try this. Isaiah wants to know if it’s useful or “too clever for its own good.”
  • For developers. There are new layout options for custom controls in the info sidebar, so you can make some grouped controls wider or narrower (one big button and two small ones, for example). More API details are coming in the next few weeks.
  • Global Find. A new tab indexes your whole project so you can search text across pages and settings and jump straight to any match. Some stack types and settings aren’t indexed yet, so file a bug if something’s missing.
  • Faster launches and better restore. More launch work now happens in the background, and your tabs, selections, stacks and themes come back the way you left them. Some of the speedup only shows up from the second launch on, because of caching.
  • Hundreds of stability fixes since beta 73, mostly found by much better integration testing.
My take: if you’ve been holding off on Stacks 6 betas, this is a good one to try. The single source list and the integrated Library make a real difference on a laptop.
Have you tried it yet? Post your thoughts below, especially on the high-density sidebar.
What frameworks are folk using on Stacks 6? Who is left! Do all stacks work and port over?
The only major issue I’ve found is that F6 warehoused images do not work either by porting or by creating with image stack or swatches. Drag & drop is fine.
Stack settings with either method simply refuses to accept image links.
Thanks Geoff. F6?
Yes sadly. It’s a major stumbling block in my workflow and I’m close to reluctantly RW another annual fee just because of this single issue. :cry:
Foundry? Or Foundation?
Foundation definitely works. Foundry 3 might work, but since it’s no longer supported I wouldn’t take the risk.
Oh yes F3 not 6. So is Foundation the only framework being supported now?
@designdisorder is working on a Bootstrap theme.
I have Blankstrap and am working on another Framework right now.
Ta. I might give that a go in a couple of weeks.
Just working on a project for my own business in Blocs.
I have both F6 and Source, and they’re running well on Stacks 6. But all the stuff I’m developing for myself is ‘blank theme’ — I don’t see the need for a platform any more, not with intrinsic grids, container queries, and fluid typography. There is a lot of exciting stuff that the Stacks world is still to catch up with (also including variable fonts and UKLCH colors) and standalone Stacks 6 seems a good moment to rethink a lot of the things we are used to. Well, that’s my take, anyway.
One thing I am find really useful, though — and it’s taken me a very long time to come around to them — are Joe’s swatches.
What issues are you having with warehouse images? They are working just fine for me. I just tested it again in the F6 picture stack just to be sure.
I did a live stream today…
