Strange character string on a Poster 1 page
Hello,
There’s a strange character string at the top of this Poster 1 page.
Deprecated : parse_str(): Passing null to parameter #1 ($string) of type string is deprecated in /home/clients/00a9616093a137b18252bb6234729d3e/web/en/tmblog/index.php on line 1029
https://www.timemanipulation.com/en/tmblog/
Could it be that it happens since I changed the PHP version on my site yesterday? Those characters don’t appear on the RW document, nor on the View in Safari"
Contact your hoster not to print PHP deprecating warnings on the HTML rendering.
Thanks Jannis, I’ll try tomorrow
[quote=“Jannis, post:2, topic:5879, full:true”]
Hi Jannis, I was very busy, but I finally contacted my host, and they’re telling me this :
“The error on your website is caused by a site development error.
You can reach out to a developer or a partner to investigate the root cause of the issue and implement a fix.
If needed, you can contact our partners here: partner.infomaniak.com.”
What can I do?
Either disable error printing to HTML in your PHP settings, or go back in the used PHP version.
Thanks Jannis, I will probably be able to fix this tomorrow
Thanks Jannis, I went back to PHP 8, and it works.
