Is there a way of changing the tags of the stacks inside RW?
If you mean the tags that are used to sort the stacks in the Library then no - these are added by the developer.
You may be able to edit these (from developers who do not encrypt their pLists) but as soon as the stack is updated then it will revert back.
hm …
Ah - ok.
Thanks, Andrew.
