Hi… we use Header Pro (I am no pro) on our site. The H1 Header on our page should read LevGo® Products. with the registered trademark symbol as a small superscript. The same problem is present throughout Header Pro.
Should I use a different Header stack?
Nigelp
13 February 2024 19:43
2
What is that Header Pro is not doing?
Jannis
13 February 2024 20:31
3
Magster:
LevGo®
<h1>LevGo<sup>®</sup></h1>
LevGo®
Or use character entity encoding: LevGo® Products.
This will look like this:
LevGo® Products .
the html solution worked inside Header Pro. The character encoding did not.
Header pro was inserting the circle R at the same level and size of the other text, no super script
In Header Pro:
This is my headerPro<span class="superreg">®</span>
In CSS (stack):
.superreg{
font-size: small;
vertical-align:super;
tav
14 February 2024 17:28
8
This is expected behaviour as Header Pro is just a Stacks header.
Technically, it is a plain text containe r (which is what Stacks headers use) and so will strip out styled text that you paste into it.
You will see that if you just paste LevGo® into a Paragraph Pro or any other stack that uses RW Styled text than you will see the superscript.
The correct solution as per the answers above from @Jannis and @Konfuzzious is to insert HTML into the header to control such things.
