Hi,
Does anybody know how when using the Overlay stack in a slideshow you can get multiple text appearing at different times to different positions on the image
I’m not entirely sure what you mean, can you link to an example?
That’s @Ricardo site, so he should know!
Hello @raman,
The site is done in UIKit3 Framework from @Lucas (Archetypon).
The stacks used for the slideshow are all from UIkit3. It’s a combination of the Slideshow, Position, Scrollspy and the Parallax stacks with the text inside. The different directions depends on the settings of Scrollspy and Parallax stacks.
Ricardo
Take a look at
https://uikitstacks.com/projects/layer/
That project file has the set up done for you
I also use these effects a couple of my projects:
The Ecwid Shop Project, here is a link for the online demo:
https://ecwidshopdemo.axyn.com
and also in this project:
https://chrisohara.axyn.com
In case you need an online shopping site.
