Has anyone else had a problem with Unlimitab with Source? I have a page which shows fine in Preview, but is blank online:
https://burghleyvoices.org/2015-concerts-and-events/
I duplicated the page, intending to delete the original, and then found that the copy views normally both in Preview and online:
https://burghleyvoices.org/2016-concerts-and-events/
I would very much appreciate if someone with more understanding could explain what is going on. It just seems random to me.
(I have done the usual clear-out of old files with ftp). Please don’t worry about the content. I know the content and layout are a work in progress.
@habitualshaker
Many thanks
FERGUS BLACK
If you add index.html to the first url, it loads. Is it possible you also have a .php .cgi or something in that folder? is the file name actually index.html in the RW project?
There is nothing at that address. Looks like whatever you saw in Preview was not uploaded to your server.
Not sure what you mean by the “usual clear-out” but this statement sounds suspicious based on what you are reporting.
I suggest you republish all files and upload to that page again.
Prizes to you both. Very many thanks. Problem solved.
Scott was right - there was an old index.php file in the folder. God knows from where.
Webdeer was also right - the solution was to republish and re-upload. I had already cleared the server, and republished to a folder, ready to ftp, but of course, the php file was obviously lurking in the desktop folder, so when I uploaded, it went back up to the server. Lesson learned: clear everything before you republish all files.
Sometimes I think that I spend too much money on Rapidweaver, and too much time, but moments like this make it so worthwhile.
Many thanks
