In Utility Classes, it seems like u-pull-left and u-pull-right don’t work?
So I think u-cf does too, but I can’t verify it.
Can you confirm? Because they don’t move left or right.
Or am I doing something wrong?
They do work but it all depends where you are adding the class name, what stack you are adding it to and what the layout set up is. There are a lot of variables that would affect whether the float happens or not.
I would advise just using a grid stack to position things as you want them.
Thank you
Sorry, I’ve confirmed that it works, and very well indeed.
“Image Plus” and “Scribe”.
By inserting u-pull-left p-l-4 into the image class of “Image Plus”, the Scribe text wraps around the image on the right; on smartphones, it aligns below the image.
It’s perfect.
Yes – best ever framework for Rapidweaver. RIP.
