Hi, i was just wondering - when using warehoused images linked to the image fit stack, does it make any difference to load times if the images are warehoused at a different, new URL. Or is it best to warehouse them at the same URL as the site. E.g. if I was using Amazon AWS for the warehoused images or something like that, and my site was on a different domain with IONOS, would this effect the load times, while the browsers loads up the images from the new URL?
Yes. Technically it could take longer loading then from elsewhere but realisticaly there is unlikely to be any noticable difference.
Keeping everything on the same server is more convenient and you don’t add another dependency.
thanks @Webdeersign . That makes sense
