I’ve not used Foundation in yonks, so can’t help on creating that using the native stacks, but…
The first example would most likely require some custom CSS, or some images with the borders and shapes etc.
The second is dead easy in pretty much any framework. It’s just a grid system, with each grid containing an icon centered and a header and text below.
The third, which would be my choice could most likely be made using Foundation stacks but personally I’d use Tavs BWD Blueprint, Sidebar and BP SVG.
If you want the hover animation, just drop the contents of each grid into whatever animation stack will do the effect you want, I think F comes with a few animation options.
EDIT: I’ve updated the project to add in some CSS powered mouseover zoom with drop shadow effect.
