Mac OS Tahoe and CLASSIC
From Discord :
Stacks 5 beta 3 seems promising as a new release.
I pushed this beta out via auto update. So if you’re running an old beta you should see it pop up next time you launch RW.
Or you can download and install it here:
Download Stacks v5.3.2 Beta 3: https://yourhead.com/appcast/RW6/beta/Stacks5/Stacks_5.3.2b3_6385.zip
Release Notes:
Stacks Release Notes
New version of the auto-update server:
if you’re using the beta
you already have this version
this version is identical to v5.3.2 beta 3.
a new beta will be out ASAP (probably tomorrow or thursday).
If you’d like to STOP using the beta, just download this release version (link below) and follow the normal install instructions.
Release version 5.3.2
  • Much more stable.
  • Work well on Tahoe, even with large projects.
  • A lot less noisy in the macOS console.
  • See the release notes for more details ( Stacks Release Notes )
You should see this version when you relaunch RW, but you can download directly here:
Release Notes
Download
https://yourhead.com/appcast/RW6/Stacks5/Stacks_5.3.2_6389.zip
